go short or long headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2011, 08:55 AM
I've got a 78 Buick regal putting a sbc350 in her, and the only thing I haven't got is headers yet...never had them before and just wondering if to go short, or long, and what is really the different in the power wise on both of them thanks
Old 10-22-2011, 09:14 AM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Unless the chassis doesn't allow for them, use long-tube headers if you can fit them. Longer tubes help to scavenge the cylinders more effectively at low and midrange engine speeds. Shorty headers are generally a compromise for tighter fits in a cramped chassis or rod with a tight engine bay.
EDIT - Some long-tube headers drop down so low as to considerably reduce the vehicle's ground clearance. If you have lowered the ride height this could come into play even more.
Old 10-22-2011, 12:25 PM
V305's Avatar
On the Border
Isn't your car a G-body? You can google gbodyforum.com, it might help you
Old 10-23-2011, 08:31 AM
if you are building a mild sbc (less than 375hp) then the difference between short and long headers is not very much. However, if you are building a "high hp" engine then the long tubes really make a big difference.
make sure to use 3/8" flanges (where the headers bolts to the heads.)
Long or Short Tube Headers? Ray102386 General Rodding Tech 13 05-12-2011 09:16 AM
long bed to short rhion1013@yahoo.com Body - Exterior 8 01-12-2010 12:24 PM
Short and long shaft TH350's.... and extra long too? 383ram Transmission - Rearend 11 02-27-2009 05:08 AM
Block hugger headers vs Long tube headers sexypizzaman Engine 12 05-01-2008 01:54 PM
short or long ?? ewhenson Hotrodding Basics 6 08-15-2007 04:15 PM
