Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - going from 3.73 to 3.08 affecting my stall speed
  #16 (permalink)
Old 03-04-2013, 08:06 AM
Hogg Hogg is offline
Originally Posted by camaro 68 View Post
thanks 496chevy,
great people on this site
the converter flash at 4600rpm. it is very good, it's a 9 inch treemaster from ATI, it is tight for the street also. I may ask them to reconfigure it to arroung 3500rpm. I think it will be even more effecient at 3500rpm.
When I complete the work (arround june), I will will let you people know the result.
Luc
What does it stall to when you hold the brake and mash the gas? or do the rear tires just spin?
Sounds like you would be happier with your loose TC and a lockup torque converter. All the fun of a loose TC and the cruise rpm just like a manual trans in high gear(1:1).
No way I would go from 3.73 to 3.08 with that loose of a TC, your TC and trans inpout shaft would almost never run at the same speed. In other words it would always be stalling, or always"on the converter".. Temps will be higher for sure with the 3.08's. City economy would be worse with the 3.08's.
peace
Hog
