Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 350 to 383...
Old 02-14-2013, 12:41 AM
gearheadslife gearheadslife is offline
Banned
heads?
intake?
you said 292 cam, comp? flat tappet? solid? roller?
1.5 rockers, 1.6? full roller rockers?
is it a 2 bolt or 4 bolt.. (I'd use main studs ARP) you mighy need a small base circle lobe cam and a comp magnum cam isn't. the rods may hit the cam.
you need to find out if the rods clear a normal cam or if you need a small basecircle cam lobe..
if so.. go a little lighter on lift, if using a flat tappet cam and make up the loss at the cam with 1.6 rockers..
