Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 350 to 383...
Old 02-14-2013, 01:28 AM
gearheadslife gearheadslife is offline
Banned
Originally Posted by 327NUT View Post
This question is asked a million times, all you'll get obviously are guesses. The only real way is to spend the money and get it dyno'd, that way you can also break in the cam under load and set the fuel and timing.
true, NOT..
600-800 for a dyno run/break in..
or a day at the track?
yes the dyno will give you a # but at a cost..
an et and mph will also..
not everyone has that much cabbage to blow to get a non real word #
to get your #'s you'd need your exhaust hooked up(most can't do this)
most don't run aircleaners.. , nor. e10 fuel
so the #'s are worthless..
