Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 350 to 383...
Old 02-14-2013, 07:48 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
chasis dynos like the mustang are great for setting fuel curve and testing timing settings.Great for simulating real road driving as load can be varied,,,,,etc worth it
How much horse power your engine will make is easy to guess if YOU,supply actual air flow readings of your heads from a certified flow bench along with cam specs.intake and fuel management system info,exhaust specs
for the layman,stock cast iron heads and flat tappet hydraulic cam= not much,,,maybe 1 horse power per cubic inch plus or minus a little.
If you donot have a good exhaust system then less
