Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 350 to 383...
Old 02-14-2013, 09:06 AM
gearheadslife gearheadslife is offline
Banned
Originally Posted by vinniekq2 View Post
chasis dynos like the mustang are great for setting fuel curve and testing timing settings.Great for simulating real road driving as load can be varied,,,,,etc worth it
How much horse power your engine will make is easy to guess if YOU,supply actual air flow readings of your heads from a certified flow bench along with cam specs.intake and fuel management system info,exhaust specs
for the layman,stock cast iron heads and flat tappet hydraulic cam= not much,,,maybe 1 horse power per cubic inch plus or minus a little.
If you donot have a good exhaust system then less
I'd not run a car on a chassis dyno without a driveshaft loop..
yes chassis dyno's add realworld to it.. and have a place, but not everyone has 500+ bucks to play at one.. or the repairs when it(the dyno) finds the drivetrain weak link.. and it will..
