Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 350 to 383...
Old 02-14-2013, 09:18 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
weak link
Originally Posted by gearheadslife View Post
I'd not run a car on a chassis dyno without a driveshaft loop..
yes chassis dyno's add realworld to it.. and have a place, but not everyone has 500+ bucks to play at one.. or the repairs when it(the dyno) finds the drivetrain weak link.. and it will..
If what you are saying is semi correct,then the chassis dyno is the best place for the car to come unglued
dont have to worry about pole vaulting a driveshaft
$500.00 is a very cheap ball park tune,especially where knock might be present.
getting exact a/f readings under power. This also gives you the ability to choose an A/F ratio to start with and then road test with a real number to start with.
street tune and race tune can both be tested on the same day.write down the results in a jounal,now knowing what a jet/air bleed chainge will do for your engine
If you build a very mild street engine then all this information will be moot
