Originally Posted by 31ROC
I am considering for the winter project, to remove the current 700R4 auto tranny, and install a 4-speed Muncie (M21 or M22?). The car is a '31 Model A coupe, with '32 frame, and Ford 9" rearend, Chevy 350 motor. Are there suggestions out there what kind of 4-speed may fit better, and are there "kits" for installing a 4 speed into this car? I assume finding a pedal assembly may be a task in itself?
Thanks in advance....
The wide ratio M20 might make a better swap than the close ratio M21/22 unless you have a 4-something rear gear in it now. If that's the case (low rear gears) you might consider a manual w/OD.
You might find using a hydraulic throw out bearing makes things easier than running a cable or linkage. There are kits for them that include the pedal assembly.
Hopefully Auto Gear will see this and comment.
Good luck.
