Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 700R4 to Muncie 4-speed '31 Coupe
  #41 (permalink)
Old 12-18-2012, 02:02 PM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by V8&4spd View Post
What year is the engine you have now? Is it a 1 piece or 2 piece seal? I saw a Model A over the weekend where someone was running a Muncie and had the pedals mounted like a later model car. He said the pedals came out of a Mustang and it had a hydraulic clutch set up. He had a old iron bellhousing that had the clutch fork on the passenger side instead of the drivers side. I would not worry about a scatter shield on a street car. The most common flywheel and bellhousing you are going to find is for the 10.5 inch clutch. If it's a 1 piece seal engine, I would look for the lite weight flywheel they used in the late 80s Corvette, the engine will rev quicker than it will with the heavier flywheel.
OK...I found this number just below passenger side head out front on the block...M02239VP, (or VR cant tell)...i cannot find this on the web, can anyone decode this?
