I'm baaaack.....been ordering parts.
Purchased Ram clutch, and Ram hydraulic throw/out brg, and Ram steel flywheel.....never owned a hydraulic clutch set-up, which brings up next set of questions for you pros out there....
Am I going to need to shim this T/O bearing, or does it go right onto the Muncie M20 as is?
I have not found a bellhousing yet, but will that determine shims or not?
When I purchased the master/cylinder for the clutch, it came with a slave cylinder, but I was reading that I dont need a slave cylinder?
Thanks as usual for all advice.....
