Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 700R4 to Muncie 4-speed '31 Coupe
  #53 (permalink)
Old 01-23-2013, 04:49 AM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by cobalt327 View Post
Bolt size for bellhousing to block is 3/8-16, length as required for the bell you have.
Same thread for the pressure plate, but a 1" under head length, and not threaded all the way to the head. Use hardened flat washers and a dab of loctite. You could use a set of ARP or similar bolts for the flywheel to crank and pressure plate to flywheel if you don't have the original hardware in good shape.
THANKS!
Am I using flat washers everywhere?
