Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 700R4 to Muncie 4-speed '31 Coupe
  #54 (permalink)
Old 01-23-2013, 12:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 31ROC View Post
THANKS!
Am I using flat washers everywhere?
Yes, all these are flat washers. You can use regular (non hardened) washers for the bellhousing, hardened washers for the PP. I don't use loctite on the bellhousing bolts, but no harm if you do.
Torque: I'm seeing 25 ft/lb bellhousing, 35 ft/lb PP and 65 ft/lb flywheel to crank. That's from Summit, I don't have a factory manual handy.
