Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going from 700R4 to Muncie 4-speed '31 Coupe
  #55 (permalink)
Old 01-23-2013, 01:34 PM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by cobalt327 View Post
Yes, all these are flat washers. You can use regular (non hardened) washers for the bellhousing, hardened washers for the PP. I don't use loctite on the bellhousing bolts, but no harm if you do.
Torque: I'm seeing 25 ft/lb bellhousing, 35 ft/lb PP and 65 ft/lb flywheel to crank. That's from Summit, I don't have a factory manual handy.
Excellent info, and much appreciated again!
