M-22 Rock Crusher 4-speed $2,150.00 |
If the customer has an assembled sidecover, tailhousing and shift forks; we can get the cost down a couple hundred bucks.
Different strokes for different folks; I don't like the way the TKO's shift; and I see the list of parts being discontinued for it is starting to grow in length. For a mild street rod; the $1500 hybrid T5 is probably the best option (Which I do not build or sell). |
Agreed. I like the old school feel and the sound of the Muncie's. The side mounted shifters are cool too.
OK.....now that the M20 has been chosen, I need advice on a clutch assembly and flywheel, and what size bell housing?......not being over 400HP on the Chevy 350, I assume a 10.5 clutch would be plenty? Not going to race, and very little "beating" if any....
(not sure if it matters, but considering hydraulic throw-out bearing) Thanks in advance.... |
I stay away from flywheels, I'll leave that to you and your engine builder. I have seen the damage from an OEM flywheel; it went off like a bomb and opened up the bottom of a 55 chevy like a P-38 can opener, the drivers door had a chunk of flywheel inside it if I remember correctly.
If you go to an large clutch (11") you'll need a new front bearing retainer (snout) for the transmission. They're not spendy and are made from the same casting as the standard diameter ones. I prefer a cast bellhousing (iron is fine in this case) for street rods, it usually eliminates the need for the offset dowels, or Quicktime if you have to have a scattershield. the offset dowelpins can be a pain in the butt, but are sometimes necessary along with a dial indicator. If you have to 'dial it in', as little run out as possible is preferred. RobbMc makes some pretty trick offset dowels, but I have very little personal experience with them For a mild street clutch, we have had good luck with Luk Rep Sets and McLeod dual frictions. I had an awful personal experience with a Centerforce that involved having problems with those wired on weights....never again; but lots of other guys have positive experiences with them |
McCleod is decent for a clutch,10 1/2 is fine,though the difference in price is not much. Use diaphram style for ease of operation. Buy an S.F.I, steel flywheel and scattershield.(read above post) The time it takes to align a scattershield is a lot less than doing a gear set. If you are too lazy to align a scatter shield then buy a blanket.
I am thinking 10.5 clutch also, but what is "diaphram style"? also, need a reputable flywheel according to you folks. Any input regarding Hayes clutches? |
hayes are good clutches too
Scatter shield is a solid steel 2 piece bell housing that is designed to keep exploding parts from coming through the floor and cutting off feet. A diaphram pressure plate has a bunch of little fingers that act like springs,the throw out bearing rides against them when dis engaging clutch,the multi finger style is much smoother and easier to release that the other 3 or 4 styles( borg n beck long style and before mentioned centrifigal weight enhanced) never mind multidisc etc |
AGAIN....great info and much appreciated...this "2-piece" bellhousing w/scattershield, is it one size? is it bigger than stock bellhousing (meaning, will I need more room under the floor compared to stock bellhousing?)
And will the clutch size (11" or 10 1/2") determine bellhousing size? |
The flywheel size is what determines what size the bellhousing has to be. Going by your statements about how the vehicle will be driven, I would recommend a cast aluminum factory bellhousing, a 10.5" clutch, and a hydraulic TOB if that's what's going to be easier for you (I'm guessing the truck was originally AT). A used bellhousing shouldn't cost much at all, under $100 I would think. Some casting numbers to look for: Need Chevy bellhousing advice Again- this recommendation is based on what you said. If you go against your own words and over rev this set up and the flywheel chews your leg off, don't blame ME! ![]() An SFI approved steel bellhousing is not cheap, but it will save you and the vehicle from heavy damage. There is a non SFI steel bellhousing made by Lakewood, but I know little about it other than it uses a 153 tooth flywheel, so it should fit well under most any vehicle. Good luck. Last edited by cobalt327; 12-12-2012 at 12:56 PM. |
| 1951 Chevy business coupe, replaced the 3 speed with a 4 speed transmission. | EricKessel | Transmission - Rearend | 1 | 08-08-2011 08:35 PM |
| Anyone swap muncie 4-speed for 700r4? | lamonicas | Transmission - Rearend | 5 | 09-25-2010 05:17 PM |
| 700r4 to muncie 4 speed | studlyrocker1234 | Transmission - Rearend | 6 | 04-08-2009 10:23 PM |
| 4 speed muncie | 79 camaro 454 | Electrical | 2 | 05-19-2004 03:44 AM |
| Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed | nightrain_rod | Transmission - Rearend | 2 | 04-18-2003 12:35 PM |
