Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Going EFI on 406 SBC questions
Old 01-29-2011, 10:55 AM
matt167 matt167 is offline
Wiki Edits: 31
Your best bet is using an entire Vortech EFI setup.. you will need to mix and match some wiring from the Vortech donor truck, but it is doable.. you could actually swap the dash and all wiring right in with little effort
