Going into my 200R4, could use advice... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-13-2011, 02:36 AM
SSedan64's Avatar
Originally Posted by S10xGN
Interesting quote from that 1st article: "Repeated reciprocation of the accumulator piston causes wear at the piston pin bore interface. After this wear reaches a critical point, fluid loss through the piston pin bore cannot be compensated due to lack of pump volume." I didn't notice any bore slop, but I do have the old 7 vane pump in this tranny...
BTW, did you get my PM from earlier this week?
Russ
Most Builders prefer the 7 or 10 Vane Rotors.
Fewer Vanes = more volume & stronger Rotor.
I've read if using the 13 Vane Rotor to never raise the Engine above Idle speed before the Trans is full of fluid to prevent breaking the Rotor.
The 13 Vane do smooth out Pump pulses and Pr. Reg. Buzz noise but, are much weaker.
Several Co.s make Billet Steel Rotors & Slides now, cost is higher but, probably worth it with 13 Vane if running higher pressures & rpm.
I noticed on Evilbay just recently the Pump kit prices have gone crazy, 3-4 times more. Mainly 2 Sellers, other sites no increase.
Todd
  #17 (permalink)
Old 12-15-2011, 07:30 AM
Bonneville462's Avatar
I'd a kept the 2.73s and put a 2.75 low gear set in a Turbo 350 or 400...
  #18 (permalink)
Old 12-15-2011, 09:21 AM
S10xGN's Avatar
Gotta love a turbo!
Huh?
  #19 (permalink)
Old 12-16-2011, 09:05 AM
S10xGN's Avatar
Gotta love a turbo!
Happy to report, the problem was "cured" by blocking the port and deleting the piston and spring. The shift quality didn't seem to change either, must be the 3600 stall mellowing things out!
Russ
  #20 (permalink)
Old 03-22-2012, 09:23 AM
S10xGN's Avatar
Gotta love a turbo!
Bringing this back up for a different input:
I'm considering installing a full manual reverse pattern VB in order to do away with the TV cable as the intake setup I'm looking at will be difficult to adapt it to and wouldn't look good.
I e-mailed my builder (Jake) who wasn't sure about some things and asked that I forward it to Lonnie Diers at Extreme Automatics. He responded back that by using this VB in a 200R4 that's been dual-fed like mine has, there would be no reverse! Undoing the dual-fed would require the trans to be diasassembled, so that's out.
What say you other knowledgeable peeps?
Russ
  #21 (permalink)
Old 03-24-2012, 03:26 AM
SSedan64's Avatar
What type Intake etc.. are you considering using?
That sounds correct, the Manual VB fluid routing probably wont jive with the Dual Fed 3rd's, seal removed on Center Support & Bolt orifice blocked etc.
Did Lonnie have any way around the Reverse problem? or maybe Chris @CK? It would probably be costly & time consuming to study the flow diagram and build a custom Man. VB.
Chris likes to do custom parts if they'll be profitable. I'm not sure if this one would be or not tho'.
  #22 (permalink)
Old 03-24-2012, 08:38 AM
S10xGN's Avatar
Gotta love a turbo!
Todd, I'm looking at the new dual-quad two plane from Holley. They just tested it in Super Chevy magazine on a 5.3L with a pair of 390 CFM's and it matched the output from a Victor Jr with the exception of 50+ ft-lbs on the lower end. I prolly could use my TV cable, but it would look like sh#$ and I'd like to change my shifter anyway. I e-mailed Lonnie again, as Jake had said something about him being involved in developing a "new and improved" manual VB...
Russ
  #23 (permalink)
Old 03-24-2012, 10:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
kinda interesting, I talked to Jake about this same deal on valve bodys last week.
I concerder Jake my ''go to guy'' on 200-4r stuff I dont know
  #24 (permalink)
Old 03-24-2012, 07:22 PM
SSedan64's Avatar
A while back Lonnie designed a 2004R Valve Body that had Constant Pressure in 1st, 2nd & 3rd but Variable TV Pr. in 4th/OD position. I think it had Manual 1,2,3 & Auto shifts in 4th/OD gear position.
The TV controlled Pr. in 4th/OD gear position takes the constant Pr. load off the Pump. Not sure if this is what Jake is referring to or not. I don't know if it worked with the Dual Fed 3rd either. It should tho' as Lonnie does Dual Feed most all that have any power hooked to them.
Since TurboBuick upgraded their site none of my old Bookmarks work.
There's a Thread that listed what to remove so they'd work & I can't find that either.
A Braided TV Cable & Billet bracket might look Ok.
  #25 (permalink)
Old 03-26-2012, 06:17 PM
jakeshoe's Avatar
I speak with Lonnie occasionally.
I "thought" when I spoke to him a month or two ago that he said he had a RMVB for the 200-4R.
I believe he was involved with the design of the TCI piece (with Greg Friend). He said it has an issue and IIRC it was with 4-3 kickdowns killing the OD roller.
I'll try to talk to him in the next couple of days and clarify.
I could probably design a forward pattern 200-4R full manual VB but I am backed up with testing a couple of other designs for 4L80Es and TH400's right now.
  #26 (permalink)
Old 03-27-2012, 09:22 AM
S10xGN's Avatar
Gotta love a turbo!
Jake, thanks for jumping in, please keep us posted!
Also, if you or anyone else knows of a shifter with a reverse pattern 4 speed gate, let me know... There's a guy on the TBB board that has a FMRVB 200R4 in a Datsun 240Z swap and is using a Quicksliver shifter. AFAIK, it only has a 3 speed reverse gate and I can't get him to reply to my PM...
Russ
  #27 (permalink)
Old 03-31-2012, 10:57 PM
jakeshoe's Avatar
Update.
Lonnie DOES make a RMVB for the 200-4R.
When you emailed you just asked about the TCI VB, he answered your question but didn't know you were still looking for a VB.
You may try to get back in touch with him.
I can get reverse pattern 4 speed shifters from one of my suppliers but will have to check pricing. They are similar to the Cheetah Turbo Action shifters.
  #28 (permalink)
Old 04-01-2012, 10:33 AM
S10xGN's Avatar
Gotta love a turbo!
Update.
Thanks Jake, I'll get back with him...
BTW, my buddy Ray (who's reworking Kent Hollier's Camaro) finally finished it up and took it for a checkout ride Wednesday. He said your 4L80 shifted flawlessly and the 'brake worked great!
Russ
  #29 (permalink)
Old 02-21-2013, 12:28 PM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
200r4E=S10xGN;1541516]Bringing this back up for a different input:
Russ[/QUOTE]
I know, OLD. But, Jim Weiss was hooking the tv cable up to the gas pedal on his 2004r conversions when doing a GS abody. I guess the th400 kick down is mounted to the has pedal and he uses this as a mounting point for the tv cable. Might be something to look into.
200r4 HEAVYCHVY Transmission - Rearend 3 09-20-2008 09:09 AM
200r4 mitchc Transmission - Rearend 2 08-06-2007 08:13 AM
200R4 on LS-1? S10xGN Transmission - Rearend 8 07-23-2005 07:08 PM
200r4 79 Malibu327 Transmission - Rearend 1 07-27-2004 12:40 AM
200r4 ID Zeder Transmission - Rearend 2 05-19-2004 06:03 AM
