Going from powerglide to th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2003, 02:45 PM
Post Going from powerglide to th350
Hello i just removed the original powerglide from my 67 camaro. I want to put a turbo 350 to replace the old one. My questions is do i have to change my crossmember? or do i have to get a off set mount?. if anyone could help me id really appreciate it.
Old 03-13-2003, 05:28 PM
abe abe is offline
Post
The turbo 350 should just bolt right up as long as u use the short tail shaft turbo 350. My Chevelle had a factory powry glide and put in a turbo 350 with no problems. I'd go for it. Like i mentioned earlier just make sure u have a short shaft and u wont have to mess with the drive shaft length.
Old 03-13-2003, 06:01 PM
Post
I believe the tail on the trany is 6 iches. is that the short one
Old 03-13-2003, 06:42 PM
Chevy Thunder's Avatar
Post
I pretty sure a powerglide and a th-350 have the exact same dimenshions it should bolt right in.
Old 03-14-2003, 04:34 PM
bigwildgrin's Avatar
Rooster
Post
yes the 350 will go right in; I did the same thing only I replaced my 350 with a powerglide. But why anyone would want to replace a powerglide with anything is beyond me...
Old 03-14-2003, 11:20 PM
Post
powerglides suck unless they are built for racing
Old 03-15-2003, 04:34 AM
Post
Thanks for the info.
