going retro from serpentine belt system back to v-belt can i swap out the reverse ro - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2007, 08:14 PM
i am using an 89 305 sbc and would like to retro fit it from the current serpentine belt system back to the v-belt setup. can i just replace the reverse rotation water pump with an earlier long pump or will that cause flow problems internally? can i use a crossflow radiator turned to mount vertically in my 36 grill shell ?
Old 06-12-2007, 09:24 PM
Water Pump Issue
At least you understand that you need a water pump that rotates in the other direction if you change to a "V" belt setup. I don't see a problem using an earlier style water pump. It should provide sufficient water flow to keep your engine cool. As for using a crossflow radiator in the up and down orientation, this should not cause a problem as long as you have your header/overflow tank above the highest point of the radiator. You can overcome a low tank mount problem by using an "Up Lift" tool to fill your cooling system where you can vacuum down the cooling the system and have the coolant sucked into the system avoiding any "Air Locks". You should have enough room under your hood to mount a header tank above the top of the radiator and avoid all of these air lock problems. The cooling system works best if you have two hoses coming to the header tank. One from the rad and another from a cylinder head to let any air in the system to work it's way uphill. Your's, Westfaliaguy.
Old 06-12-2007, 09:38 PM
DoubleVision's Avatar
Just out of curiousity why change the serpentine? is it due to lack of A/C? if so you can get a bolt on pulley arrangement and keep the serpentine. Once I went serpentine I`ll never go back to V belts.
Old 06-22-2007, 06:54 PM
retro to v-belt
westfaliaguy,thank you for the info,i have been seeking this information on the mounting of a crossflow vertically for some time now and am thankful for the response.i am still curious about mounting an extra tank above the radiator, cooling systems are not my strong point,and you mentioned an extra hose setup to avoid cavitation,on a sbc what would be a good place to tap into so that it would look professional. could i use a modified coolant overflow tank above the radiator and would i have to weld on a filler neck etc.?
doublevision howdy, thanks for the reply. i am basically trying to retro back to the fifties look,running an open sided hood setup and only retaining the 2 piece top section using dzus fasteners to attach it to the cowl and the grille housing,the old batwing oldsmobile aircleaner and those nostalgic olsmobile aftermarket "rocket" cast valve covers,and the v-belt setup.
Old 06-22-2007, 06:59 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What is the purpose of mounting crossflow radiator vertically? Why not use a radiator specifically built to fit your application?
Old 06-25-2007, 07:56 PM
back to v-belt
basically i am trying to keep the cost down and i can find an almost new crossflow at the pic n pay [boneyard] for very negotiable funds,i.e a crossflow from a late model v-8 wagoneer will fit vertically a supply the cooling area and volume that i need for a sbchevy and still go home with an extra 300 smazolies for some other items,like that early ford bronco rear axle assembly which is only 54" wide to my stocker which is 56" wide and it comes with a 5 on 5 1/2" pattern to match the early ford 5 on 5 1/2" i am converting to on the front end to run early ford reversed all around.
thanks for the question,blazin,it was a logical inquery,but sometimes us old bucks arent that logical but we are thinkers,you know something like what if i split the exhaust manifold on that gimmy six in a row and welded a plate in the middle and cut a second opening to make dual exhaust,i wnder how she will sound with dual smithys and straight pipes,im just sayin.
that was 1962 here it is 07 and im still thinkin,you know like what if.......
Convert 70's Chevy 350 to serpentine belt system? Hippie Engine 17 07-13-2015 07:18 PM
What years are reverse flow engines? Ozz1967 Engine 19 08-20-2006 07:48 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
serpentine belt system crash70rs Engine 10 08-30-2003 03:52 PM
