Going From Small Block To Big Block In '71 Nova... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2008, 06:18 AM
What changes will have to be made to go from 350 to 454 in a '71 Nova? Will it fit with the stock brakebooster( power brakes)? Will the power steering need changes? Any suggestions?
Old 07-13-2008, 06:22 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I can't answer the other questions, but the heater box is flatter on a big block Nova.
Old 07-13-2008, 02:06 PM
I was wondering about that also..
Old 07-13-2008, 02:57 PM
DoubleVision's Avatar
Make sure you use the correct big block mounts, the small block mounts will make it sit too high and cause clearence issues.
Old 07-13-2008, 03:14 PM
ericnova72's Avatar
More for Less Racer
Need correct Big-Block frame mounts, correct heater box cover and correct heater core as the pipes come out in a different position, can't use tall valve covers with power brake booster (IIRC), and big-block bracketry for the steering pump, box is fine as big-block frame stands move entire motor 1" to passenger side. Turbo 400 trans crossmember is also offset 1", but you will have to alter the Turbo 350 crossmember for this offset if using a Th-350.
The 400 crossmember is available reproduction.
does the small block chevy have a "proper" name? Hoxviii Hotrodders' Lounge 62 11-21-2009 07:50 PM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
big inch small block Streetnova Engine 7 01-11-2007 08:12 PM
small block, big block crevette Hotrodders' Lounge 3 04-13-2003 08:35 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
