How does it run? I can tell you 120 psi isn't very high even for a worn stock 350. Are you sure of your gauge condition? If you added oil and compression didn't jump, that means the valves or valve is leaking. Might try running top engine cleaner threw it may just be crud on the valve seats. If it doesn't miss I wouldn't tear it down.
No misses at all, runs smooth as ever. ya i also agree that the compression is low anyway but the motor was in the truck when i bought it. I also ran some crud remover through it today and compression stayed the same. Maybe some drivin will fix it.
when you say valve recession do you mean that the valve seat sinks deeper into the head then causing the valve to be held open at what was previously proper ajustment? This is what i believe you mean.
I figured that if anything the valves would become looser over time considering the compression was 120 PSI in all cylinders a year ago but i had never ever thought of valve recession. i will check the valves on that cylinder as soon as i can. Last edited by Scrumgees; 03-27-2006 at 11:03 AM. |
Not with hydraulic lifters. They automatically ajust for this. |
Recession is when the seats pound out and the spring pulls the valve up, thereby increasing its installed height.
At 1 turn on a 5/16 unf thread you get approx 40 thou per turn (similar to an 8x1mm thread). One half turn at the rocker stud gives approx 20 thou lifter preload. If the valve recesses 40 or 50 thou the lifter can't compensate, Crane and others make rocker pedestal shims in varying thicknesses to solve this on 302/351c's and others with non adjustable rockers - cheaper than adjustable pushrods. |
| looking for some head(s) now i'm gonna explode! | bullheimer | General Rodding Tech | 25 | 04-12-2004 01:16 PM |
| Im gonna go all out when painting my camaro. | Rubberman2003 | Body - Exterior | 3 | 02-04-2004 05:29 PM |
| what's gonna happen in 10 yrs? | Hollywooding | Hotrodders' Lounge | 60 | 02-01-2004 08:46 AM |
| I'm Back!!! I'm gonna get a 350! | 2506CYL | Engine | 4 | 04-19-2003 01:38 PM |
| Is chevy gonna build another "muscle" car?? | '54-Hunter | Hotrodders' Lounge | 36 | 02-28-2003 09:00 PM |
