good aftermarket cam 302 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 08:18 PM
Last journal entry: studebaker m5
Just looking for some suggestions on a good cam for a stock 1979 ford 302.Im running and autolite 4100 600cfm 4bbl carb On a cast iron 4bbl intake,Shorty headers.Its an FMX automatic with 2.79 rear gear ratio.I have used a crane cam in a similar motor years ago..it had 262 duration,I dont remember the specifics (15yrs ago) but i chose the cam because it favored the exhaust side.I liked the way the motor performed after i installed the cam..Now i want to put in another cam in the 302 im running now,But thought of using a duration of 268 or 272..how much lift? i know being a stock engine i dont have many options.What say you guys?..its just a stock engine,And 'simple as possible' answers only..i dont do well with numerous mathematics,i dont want to go to the moon..just looking for a little 'rumpity rump' sound and some more power
Old 04-05-2013, 08:24 PM
vinniekq2's Avatar
top of the page cams are what you need.Like what you had before.Buy from a reputable manufacturer
Old 04-07-2013, 12:28 AM
I have another rear axle im going to install,it has 3.73 gear ration
Old 04-07-2013, 03:15 AM
Nemeth's Avatar
My 327 Cruiser
302 cam
With the rear end ratio of 373 the comp cam xe268 is biggest cam for stock converter and has lope, Also the comp cam dual energy has a 219 int and 229 exhaust duration, higher ex for poorer flowing heads the lift is low enough to not have to worry about coil bind. This one to will give you a nice lope also.
sure hope this helps.www.compcams.com
Old 04-07-2013, 03:20 AM
Nemeth's Avatar
My 327 Cruiser
302 cam
Just to clarify go to the link I sent. It is either a dual energy or the High energy cam from comp . both work with stock converter.
Old 04-07-2013, 08:42 AM
vinniekq2's Avatar
cam selection
the 3.73 gears are for the purpose of the car more than the purpose of the engine.If you are wanting a bigger cam,then the CR becomes an important issue.The cams job is to allow the heads a chance for maximum flow.If you know the CFM the heads can flow ,the deck height of the pistons,the CR,then you can "match" the cam.You will need the correct combination of intake and fuel management,,,and the headers and exhaust also need to match.
The answer is in the combination,not just a cam.
Ford 70's 302 cam allclassicsbefore70 Engine 7 07-21-2011 07:59 PM
Ford 302 cam help Les's73F100 Engine 8 10-19-2009 06:54 AM
Need Cam help for a 302 Ford RetroJim55 Engine 4 03-04-2009 10:58 PM
Good Hotrod Cam for 302 RetroJim55 Engine 11 11-07-2008 03:00 PM
ford 351 cam in a 302 jackodom Engine 4 05-30-2006 12:37 PM
