-   -   good air bag setup? (http://www.hotrodders.com/forum/good-air-bag-setup-167866.html)
56chev100 11-04-2009 12:46 PM
good air bag setup?
generation 2 bridge kit 230.00
heavy duty triangulated 4 link kit 330.00
2 Air Lift Dominator D2600 600psi baggs 1/2" ports
2 SMC 3/8" valves
2 3/8" valve fill control with PTC fittings
2 3/8" NPT valve dump control
a pump out of an air ride caddy, and 2 port 3 gal. tank
all parts from www.suicidedoors.com except pump and tank
so does this seem like a good suspension setup??
88_mopar 11-04-2009 01:12 PM
What vehicle?
56chev100 11-04-2009 01:51 PM
1956 ford f100
88_mopar 11-04-2009 02:18 PM
That should hold up the rear well but if you plan to bag the front id get a bigger tank and better compressor.
56chev100 11-04-2009 02:22 PM
cool thanks i do plan on bagging the front later do you know of a good kit for the front? doesnt it just need adapter plates and then you put bags right were the springs were? it has a 91 camaro clip
88_mopar 11-05-2009 06:56 PM
Should just be bags and cups and a shock relocation. Or you can go with shockwaves if you have the coin.
56chev100 11-07-2009 12:16 AM
do you know of a good place to get cups? im getting everything else from suicidedoors.com
88_mopar 11-07-2009 07:36 PM
Might as well get em there. A front bag kit for an s10 should work good. Comes with cups, bags and a shock relocation kit.
56chev100 11-08-2009 01:12 AM
ok sweet thanx for the help man
