Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - good and bad
Thread: good and bad
Old 06-06-2004, 01:22 PM
LanceM LanceM is offline
Almost an old guy...
While you had it apart did you put in a new oil pump? Typicaly low oil pressure and a "wacking" noise means bearing problems, excessive clearance on the mains will give you low oil pressure.
Other questions:
Mechanical or electric gauge? If electric maybe a bad sending unit.
You said that it did this before the ring change, did you check the mains while you had it apart?
