Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - good and bad
Thread: good and bad
Old 06-06-2004, 03:45 PM
jrm123180's Avatar
jrm123180 jrm123180 is offline
A Learning Hobbist
my gauge is mechanical.....
could it be that i bent my oil pump and its too close to the bottom of the pan?
before I did this job, i would loose oil pressure but that went with the oil. as soon as I added more oil, the pressure would come back up...but not to where it should be. The motor has 150k on it and the pump is original to my knowledge.
Are the bearings something that can be done with this engine in the truck? should i just replace my pump and see if that does anything?
thanks for eveyones help
steve
