Good Brake Vacuum Source?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2009, 12:17 PM
I just recently put a small block chevy 350 that i built myself into a 1985 s10. It's a 2wd short bed with a turbo 350 transmission. I had the brake vacuum like coming out of the brake booster hooked up to the breather on the valve cover to see if that would work because i know there's some vacuum in there but my brakes are terrible i have to put all ive got into it. I know that you're supposed to use a better vacuum source. What can I use for a good source? I have a spare vacuum fitting on the front of my holley street avenger 670cfm carburetor, but it's a tiny fitting something like 1/4". The line coming off of the booster has got to be 1/2" or so. Also, I have an edelbrock performer RPM intake manifold. Thanks for the help
Old 02-09-2009, 12:52 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You need to get the vacuum from the intake manifold, on the manifold behind the carb their should be a plugged hole to screw
a fitting into to attach the vacuum hose to, open the hood on another Chevy & look at how it's set-up, also check that hose your now using for oil on the inside, you don't want any in there
Get back to us with the outcome.
Rich
Old 02-09-2009, 02:27 PM
I see the screw and where i previously plugged it up. Where can i get some sort of fitting that is able to clear the rear of the carburetor? There's only maybe 1/2"-3/4" of space under there. Thanks
Old 02-09-2009, 03:05 PM
Hi,
If their is a napa store near you go there because the parts people there are normally a more informed then the other chain
stores, they should have what you need a short 90*
you may need to remove the carb to install it.
Rich
Old 02-09-2009, 03:54 PM
awesome, thanks for the help guys
Old 02-09-2009, 04:03 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I was looking at the parts stores for that 90 degree fitting. Never could find it there. I ended up in the plumbing section at ACE Hardware. It took me a couple tries, but it was there. Only a couple bucks too.
Old 02-09-2009, 05:18 PM
Hmmmm. mine is hooked up to the back of my Quadrajet carb as a vacuum source: bad news?
Old 02-09-2009, 06:35 PM
weirdbeard's Avatar
1976 Ranchero GT
When ever I see a Q jet the booster is always plumbed to the back vacuum port.. It may even be a factory hook up. Not sure about that.. Works just fine.
Locking full centrifugal advance and vacuum question bubbahotep Engine 26 08-12-2008 09:23 AM
Good source for Rod Kits Tony_D Hotrodding Basics 1 05-31-2006 02:21 PM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 04:41 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
early optispark vacuum source 48Man Engine 7 01-16-2003 01:17 PM
