Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is this a good buy?
Old 09-16-2005, 04:50 PM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
Last journal entry: Vise jaws
If you are going to use it to pull a car up onto a trailer....Nope!!!! That 1000 lbs. rating is for pulling on lever ground, preferably asphalt, smooth, coated with sealer twice, etc. They have fine print on the boxws that you do not see until after the thing is bought. I bought an electric winch at a swapmeet that was rated for something like 3000 lbs. You attached a plate to the trailer, the winch attached to it (it was removable), long cords to hook to the battery, and a remote. It was a good thing it had an auxillary handle with it. Weimer and I used it a couple of times but it was a POS. Once a car starts to go up ramps on a trailer, your angle of pull changes, therefore decreasing the pulling capacity by quite a bit. If you had all the angles and heights you could mathematically figure it out but I would suppose it would be the same as increasing the weight of the vehicle about 4 times. I wouldn't waste my money if I were you. Take that money and then some and save it back for a good winch.
