Is this a good buy? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2005, 07:45 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Is this a good buy?
While browsing the HDC website, I found this cable winch. 1000 lb pull of 3/16" cable. Sure looks like it would beat the old come-a-long and chain. I'm not overly knocked out about three bolts to mount it, but I am a rodder. And you can alway improve things, right?
In a while, Chet.
Old 09-16-2005, 03:03 PM
USA1's Avatar
The price is certainly reasonable. How could you go wrong?
Old 09-16-2005, 03:50 PM
Kevin45's Avatar
Just one of the guys
If you are going to use it to pull a car up onto a trailer....Nope!!!! That 1000 lbs. rating is for pulling on lever ground, preferably asphalt, smooth, coated with sealer twice, etc. They have fine print on the boxws that you do not see until after the thing is bought. I bought an electric winch at a swapmeet that was rated for something like 3000 lbs. You attached a plate to the trailer, the winch attached to it (it was removable), long cords to hook to the battery, and a remote. It was a good thing it had an auxillary handle with it. Weimer and I used it a couple of times but it was a POS. Once a car starts to go up ramps on a trailer, your angle of pull changes, therefore decreasing the pulling capacity by quite a bit. If you had all the angles and heights you could mathematically figure it out but I would suppose it would be the same as increasing the weight of the vehicle about 4 times. I wouldn't waste my money if I were you. Take that money and then some and save it back for a good winch.
Old 09-16-2005, 04:27 PM
schnitz's Avatar
Wiki Edits: 54
My dad might have an old grain elevator cable winch that uses (I believe) 1/2" cable. I remember it was heavy as snot to use, and probably needs new cable by now. I'll have to look and see when we are there again.
In a while, Chet.
Good quality TIG welder which one?? sevt_chevelle Body - Exterior 8 01-05-2006 06:58 PM
what are you going to buy? akm Hotrodders' Lounge 11 11-15-2003 02:18 PM
350 and good gas milage and a combo HELP changer01 Engine 7 09-22-2003 11:05 PM
Help!..Where can i Buy AFR 165 Heads? sum87mustang Engine 2 09-22-2003 09:33 PM
Is this a good trans to buy Pro1972nova Transmission - Rearend 4 12-11-2002 07:05 PM
