good cam for a 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2011, 11:36 PM
good cam for a 305
looking for a good cam for a stock 305 edelbrock carb and manifold headers this is on a 86 s10 blazer gotta wake that 305 up im thinking off the line
Old 03-25-2011, 12:03 AM
Everything is HAMMER!
Flat tappet or roller? For FT I'm thinking summit sum-k1102 ,for roller comp xe258hr.
Old 03-25-2011, 12:06 AM
GMMAN's Avatar
Its a never ending game....
I would go with a comp cam extream energy like a 268 and a 2300-2500 stall.
With that cam, you will not need different valve springs and it will still idle great and give you enough vacume for brakes.
The stall helps with off the line as it lets the vehicle leave in the camshafts powerband, compared to before it. But with a stall, you will need a tranny cooler( they are cheap at the junk yard)
Old 03-25-2011, 12:25 AM
JeffB's Avatar
www.jegs.com check out the Crower Beast part# 258-00904
Old 03-28-2011, 11:09 PM
Silverback's Avatar
Boost Retard
Typically, a few degrees shorter than what you'd use in a similar 350...
If you want a specific answer then give specific details about the drivetrain, powerband, intake, exhaust, chasis weight, use...
Old 03-29-2011, 12:33 AM
i gave specific details in my post carb manifold s10 blazer and off the line power is that detailed enough
Old 03-29-2011, 02:56 PM
Silverback's Avatar
Boost Retard
Does that even answer half of what I asked? Go to any cam manufacturor's web site and check out the list of what they want to give you a good recommendation. Without those kinds of specific details you'll only get vague shots in the dark based on what people would put in there own setup for their own use... who knows if that will match with whatever you want to do
Old 03-29-2011, 03:14 PM
Hippie's Avatar
Last journal entry: HEI comparison.
"Specific details"? Not even a good start! I think I speak for most of us here when I say "we're not friggin' psychic", you have to give us something to work with. What trans, gears, tire size and which "stock" 305? There are 305's and then there are 305's, they weren't all created equal and S-10's didn't come from the factory with 305's. What year 305, what Edelbrock carb, was it a 2 or 4 Bbl. carb originally or was it EFI and if EFI TBI or TPI converted to a carb?
Old 03-29-2011, 03:42 PM
malc's Avatar
Living At The Speed Of Life
I installed one of these Crane Cams in my Camaroīs original 305, with 1.6:1 roller rockers gives great torque.
When I went to a 350 the cam came as well.
Itīs excellent off the line but runs out off puff at 4400rpms.
Good salvage yard--Good prices impalaman63 Hotrodders' Lounge 2 07-06-2010 08:24 AM
whats a good price for good th-350 and 400 cores? jeffvega Transmission - Rearend 7 03-08-2009 05:15 PM
Herculiner Bedliner, Good or no Good? chevy3600 Body - Exterior 3 03-02-2008 07:55 AM
color combo, good or no good IROC100 Body - Exterior 13 12-11-2007 12:17 PM
another useless post about myself. the bad got good the good went bad bullheimer Hotrodders' Lounge 6 09-29-2004 07:57 AM
