good cam for a daily driven sbc350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2003, 06:50 PM
.030 350 chevy
9.1 compression
750 holley
performer rpm intake manifold
vortec heads
1 5/8 headers
dual 2.5 exhaust
4.10 gears
muncie 4spd
wondering if i could get some advice on a good cam for this combination that still can be daily driven
Old 11-21-2003, 07:22 PM
Jmark's Avatar
This is my choice for my 350.
Good idle, good vacuum, largest available without going to a higher stall converter. Good torque and midrange power. Available at Checker for $119 cam and lifters kit.
Old 11-22-2003, 04:03 AM
thrasher's Avatar
New Member
Since the Vortec has a fairly poor flowing exhaust port you should use a dual pattern camshaft.I would go with a CompCams XE262H or the XE268H.
If you had an automatic I would go with the XE262H without question.This is because of the compression.You need about 9-9.5:1 to get really good bottom end with it.
The XE268H will need a little more to get really good bottom end with an automatic,about 9.5-10:1.
But since you have a 4spd and 4.10's there is no sense of even preaching about the need for bottom end.
The XE268H should very work well.The reason that I would go with the XE268H is that with a 4spd you tend to rev the motor out more in daily driving and this will provide you with some top end poop which you will need with the 4spd.
