Good Chevy Rear for mods? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2006, 05:22 PM
I am scratchbuilding a custom 34 chevy, i don't want a ford 9", what is a good chevy version? Somthing that aftermarket gears and axles are readily available.
Something that is cheap would also be great, what vehicle to take out of?
Brendan
Old 01-23-2006, 06:15 PM
mxmuscle's Avatar
a 12 bolt out of any car ,probably a camaro, nova or chevelle. The 2wd truck is good too, but harder to find gears, and lockers.
Old 01-23-2006, 06:37 PM
Brendan
The 9 inch Ford is the most used, most transplanted rear in the Automotive world for GOOD reason.......
Old 01-23-2006, 06:43 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
An 8.5 inch out of any car or truck will do you just fine for up to 400 horsepower and an automatic transmission, 350 hp with a standard.
Easy to find parts for and cheaper than most others because they've been in production for 30 years now.
Old 01-24-2006, 10:50 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Agreed... a stock 8.5" isn't much weaker than a 12 bolt, and debatably as strong as a truck 12 bolt. Not to mention the prices you pay for a passenger 12 bolt these days are outrageous.
An 8.5 with maybe an Eaton posi (skip the factory Auburn cone-style posis), bearing cap studs, a preloading cast cover, c-clip eliminators, and good quality axle shafts will take a TON of abuse. I'm planning on giving mine 500hp/500tq with 4.10s and a T56 six speed here soon. But I'll be limited in the traction department with 285mm rubber.
You can snag disc brake 8.5s from several cars and late s10 trucks. Taxis, cop cars, impala SS, some 80s caddys, late pickup trucks... just start hitting the junkyard and look for 8.5". This website lists them by photo:
http://truckparts-specialists.com/ca...ture-guide.htm
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
71 chevy truck rear end choppy71 Transmission - Rearend 14 09-23-2005 01:55 PM
How to identify the year of a Chevy 10 bolt rear End? frankenvette Transmission - Rearend 2 04-07-2005 10:14 PM
48 Chevy Truck rear fenders bg Body - Exterior 2 10-31-2003 06:30 AM
