you'll be about 425 to 450 horse and be turning well into the 12's.
If you built a motor with a few more cubes you wouldn't have to turn it so hard. That 350 is going to be shifting about 6700RPM which is going to require some attention to detail in the form of $$. K |
good combo
my friend doesnt even know what size engine it is. he said alll he remembers is the man said it was bored out and i took a guess and said it was a 350. but would that combo work well with a 383 or a 400 cuz if the engine is too worn he said he'll just get a new block.
My guess is that you will be somewhere in the 450-500 hp range. That power in a 2900 lb car should pretty easily put you in the 11's. Here is an article from the AFR website with a motor very similar to yours. The main difference is that in the article they use a mech roller cam but it is about the same size as the cam you are looking at. I am not positive, but I think they used street ported heads in the article whereas you are using comp package.
http://airflowresearch.com/articles/article54/A-P1.htm Adam |
1969NovaSS,
On your combination we'd recommend using a 650 Mighty Demon carburetor P/N 5282010GC. Depending on how the assembly goes you should be about 460 to 480 HP and about 430 FT/LBs |
| 68 chevelle good deal, not good deal? | MMkokinda65gto | General Rodding Tech | 3 | 02-27-2005 06:48 AM |
| combo help, camshaft rec? | Roy_67_SS350 | Engine | 1 | 02-28-2004 06:34 AM |
| please Check my 383 combo..I need some help | terror385 | Engine | 18 | 01-17-2004 06:47 PM |
| GOOD REAR END SETUP FOR A 68 CHEVY TRUCK | erik350 | Transmission - Rearend | 1 | 05-14-2003 07:35 AM |
| where can i get a good paint | integra_2222 | Body - Exterior | 3 | 07-29-2002 06:21 AM |
