Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - good deal on the bridgeport mill?
Old 07-04-2011, 07:06 AM
trees trees is offline
Unless it is worn out, I would scarf it up faster than a snake strikes. Of course, if there is no tooling to go with it, you will spend at least that much to be able to do simple things. Personally, I like moving the table up and down vice the head. Check for excessive wear on the vertical table lands as well as screw wear on the table horizontal movement.
