Is this a good deal or what - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2007, 06:03 PM
RPM Machine » Product » Economy 355 Chevrolet-Dome Piston-up to ...
Economy 355 Chevrolet-Dome Piston-up to 400HP
Product Overview
355 Chevrolet Stroker Kit:
Street Kit up to 400 HP
Block: Stock 350 chevrolet or aftermarket block 4.030 bore
Kit specifications and standard components:
Pistons: Economy t-5 heat treated h-series, flat top piston
Connecting Rods: Scat 5.700 I beam 3/8 cap screw rod bolt, pressed pin
Crankshaft: Scat 9000 series 3.480 stroke 350 main 2.100 rod journal
Product Details
Stroker Kit Piston Combinations
Claimer
Piston Compression Ratio 58cc 64cc 70cc
Dome/ Dish Volume
Flat Top 11.2 10.4 9.1 Call
Dish Piston n/a n/a n/a n/a
Dome 12.7 11.6 10.1 Call
Stroker Kit Options
Kit "A" Includes Crank Rods and Pistons
Kit "B" Includes Crank, Rods, Pistons, Bearings and Rings
Kit"C" Includes Crank, Rods, Pistons, Bearings, Rings, and Balancing, (Bi- internal Be-external)
External Balance Assemblies Include Damper and Flexplate
SKU#: 1-92305-1
Our Price: $475.00
Add bearings and rings for $70
Add balancing to kit $175
See what i mean what a good deal
Old 09-09-2007, 06:07 PM
the bore is suppose to be 4.030 for the kit,
what is the stock bore size for a 1968 GM 350??
Old 09-09-2007, 06:12 PM
Notorious's Avatar
Hot rodder, not street rodder!
4.00" But my question is why are they calling it a stroker kit if it has the stock 3.480" stroke?
And a word of advice. Never assume that a mail order rotating assembly is "balanced" regardless of claims. Have a competent machinist who's familiar with performance builds verify it. For good deals on internal components check out cnc-motorsports.com They were the best deal I found for the components I needed when I did my last serious build last year.
Old 09-09-2007, 06:16 PM
that is weird maybe i should email the company
Old 09-09-2007, 06:27 PM
the up to 500 horse stroker kit has the 3.480 stroke also
Old 09-09-2007, 06:37 PM
302 4.000 bore 3.00 stroke 327 4.000 bore 3.25 stroke 350 4.000 bore 3.48 stroke 383 stroker 4.030 bore 3.75 stroke
Maybe its a stroker kit for a 327 I would be a little leary as it seems they are trying to mislead the buyer. $0.02
Shane
Old 09-09-2007, 06:53 PM
im not sure what to think about it now
Old 09-09-2007, 07:24 PM
Notorious's Avatar
Do your homework and determine exactly the parts that you require for your needs. Once you have specific part numbers for the hard parts you want, you are the master. The numbers of companies selling engine parts online is virtually limitless and it's a buyer's market if you shop smart. Good luck and there are plenty of us who will help if we can with any specific questions. Don't nit-pick over a few bucks if a given company can supply you with everything you need at any given stage of your build. And of course use your instincts when communicating with any vendor. If you feel they're giving you the bum's rush, blow them off and look elsewhere. If they're patient and helpful with all of your questions and concerns, that's a good sign. If they're just selling parts and try to blow you off, screw 'em. Communication is everything to me, whether buying online, locally or from an individual.
Old 09-10-2007, 03:01 PM
Product Overview
Product Details
Claimer
Dome/ Dish Volume
Stroker Kit Options
SKU#: 1-92305-1
Our Price: $475.00
Sounds like a 350 full of Chinese parts, for what its worth; "you get what you pay for", or less.
Bogie
Old 09-10-2007, 03:15 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Bogie
I agree, with emphasis on the "or less" part.
Here's the site that notorious mentioned. Check out the most popular kits on the right side of the page....
http://www.cnc-motorsports.com/category.asp?CtgID=9001
Old 09-11-2007, 06:50 AM
thanks for the help
Good Deal :-) Oooohhh Shiney... 1Fast65Elky Hotrodders' Lounge 3 04-21-2007 06:10 AM
Good deal 4 me! HemmiGremmie Hotrodders' Lounge 3 01-18-2006 08:54 PM
does this sound like a good deal? strracer7 Engine 8 09-06-2005 05:27 AM
Good deal on engine? arch Hotrodders' Lounge 2 10-23-2004 01:45 PM
Kugul Komponents, where can i get a good deal? AHotRod Suspension - Brakes - Steering 1 04-18-2002 08:03 PM
