good disk disk breaks system - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2011, 04:35 PM
A Little back ground. I have an 81 Datsun 4x4 that i have done and sas with a jeeps j10s axles. I have hydro-boost from an astro van. I used the master cylinder and prop valve from the jeep. Last year i put rear disk breaks on it. It dint take long to realize the set up i had was not gonna work. to much stopping up front not enough in the back. So today in my local pick a part i cam across an 81 caddy with disk disk. so i grabbed the master and prop valve. I know a lot of folks go for the vett master but i have 8 bucks in this so if it ant no good no big loss. I used gm metric calipers, and the slandered gm s up front.
Is the caddstuffuf worth using?
front disk breaks SoCal1 Suspension - Brakes - Steering 6 12-06-2010 09:43 PM
oem MC and prop valve on disk/disk nskeeter99 Suspension - Brakes - Steering 1 07-10-2009 09:07 AM
disck/drum to disk/disk tomthecomic Suspension - Brakes - Steering 5 10-29-2007 08:53 PM
disk breaks carnell Suspension - Brakes - Steering 3 11-06-2003 08:44 PM
what disk breaks can i use...? 63newportPR Suspension - Brakes - Steering 1 06-13-2003 11:17 PM
