Good Gear For The Street - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2009, 02:33 PM
wormy5's Avatar
What do you think would be a good gear for the street. I was thinking 3:55. 26x10
Old 01-23-2009, 03:31 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
It depends on a few things,Like the size of your tires for one.
Old 01-23-2009, 03:52 PM
runn141's Avatar
SB S10
i say a 3.42 to 3.55 with a 25.4 to 26.0 tall tire.
Old 01-23-2009, 04:21 PM
Overdrive or not?
Old 01-23-2009, 04:31 PM
wormy5's Avatar
No overdrive using a 350 turbo.
Old 01-23-2009, 04:41 PM
I run 31s with a nv3500 & 3.42s. Under 2k@70
Shane
Old 01-23-2009, 04:43 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
i like and i am running 3.73 with th350 and a stall converter on 26 in tires.and it does really well.
Old 01-23-2009, 05:00 PM
68NovaSS's Avatar
Wiki Edits: 9
I'm running 4:11's, but we don't have the freeways most of you guys have to deal with. Let's see, 4:11's, 31" tire, 3200 stall, yep, right about 3 to 5 mpg, but it'll jump right out from under ya.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 01-23-2009, 06:27 PM
runn141's Avatar
SB S10
http://www.ringpinion.com/Calc_RPM.aspx
Old 01-24-2009, 01:21 AM
SSedan64's Avatar
Another good Calc.>> http://hotrodworks.net/hotrodmath/quarter.html
Old 01-26-2009, 11:54 PM
gear qus?
i think if your running a big block and alot of torque you need to give the engine enough room to use the torque. So in my opinion its only my opinion but a 3 series like 342 but 373 would be as deep as i would go if i had a small block freeway driving never happened, by that i mean all my driving under 55 or 60 and that is running tight 4 series all the way there cool at the light. Big blocks dont like the rpm's unless you really spend some money and then its a whole new monster hooking it up! good luck
How do I remove the timing chain on a 350? piniongear Engine 9 09-20-2010 09:39 PM
New Holley carbs any good? (4160, Street Avenger,etc) Saito Engine 1 08-11-2008 05:25 PM
12 bolt 4.56 gear ? jody chevelle Transmission - Rearend 8 02-04-2006 12:19 PM
is this a good street engine? Mike_82 Engine 5 03-19-2004 09:31 PM
Orlando Back street drags? DragLinkscc Hotrodders' Lounge 2 12-17-2002 06:43 AM
