Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $5,528.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-06-2008, 06:49 PM
RetroJim55 RetroJim55 is offline
Good Hotrod Cam for 302
I have a 1983 Mustang 302 , headers with 600 Holley that I will be putting into my 55 Ford Fairlane . I will have a 4 speed manual trans with 4:10 rear . I want a good sounding cam with good lope for car shows and cruise nights . Hard or rough idle is no problem . This car is a toy , not a daily driver !! Will stand on it when I can get away with it ! just a good sounding cam with good low to mid range , 2000 to 5500 rpm on street .
I want to use flat tap cam , don't want to go roller cam .
Will run open exhaust when I can get away with it too .
Any and all good sugguestions will be very helpful !
Thank you for your time !
Old 11-06-2008, 06:57 PM
ap72 ap72 is offline
How fast is fast enough?
look into low end circle track cams- it'll give you a very noticible idle, great power too. Call Isky up and tell them what you want, and that you want to go with an agressive solid tappet cam and EDM lifters. If you want I can go through the lobe catalogs tomorrow at work and come up with something really nice.
Old 11-06-2008, 07:26 PM
That would be very helpful ! I have used Isky from back in the 70's and always had good performance from them with no problems . Here I have a great dirt track in my back yard and didn'r even think of what they use . They have a flea market end of the year this Sat and I always go and have found many good deals there . I live 1/2 mile from Lincoln Speedway in New Oxford PA. Really Abbottstown but nobody knows our tiny town .
I can also talk with the guys down there too .
I would still like all the help I can get before I go buy something !
Old 11-06-2008, 07:29 PM
Just off the top of my head I'd say look for something with high 230's @.050" on the intake, a few more degrees on exhaust and a 110 LSA. I'll get more indepth tomorrow.
Old 11-06-2008, 11:06 PM
JeffB's Avatar
JeffB JeffB is offline
You might want to check this out,at Summit Racing you can get the Cam & Lifters for $100 part# SUM-K3600 I have this in my '84 302,this grind is the same as the Ford Motorsports cam that sells for $140 just for the cam.I have Hi-Po "K" code heads,RPM intake and a 625 Carb it is in a '54 Ford sedan,I have an AOD and a 4.10 rear,awesome accelelation and sounds very healthy.
Old 11-07-2008, 02:26 AM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
techinspector1's barnstar
Wiki editor
Last wiki edit: Cam /compression ratio compatibility
Wiki Edits: 247
Checked out 14 solid flat tappet CompCams at different CR.
At 9.0:1, 31-609-5 did best. 395 hp, 381 tq. 285/295, 250/260, .568"/.592", 106 LSA, 3000-7000, 4-spd or 3500 stall converter.
At 10.0:1, 31-609-5 did best. 412 hp, 396 tq. Same specs as above.
At 11.0:1, 31-335-4 did best. 420 hp, 403 tq. 294/294, 248/248, .560"/.560", 110 LSA, 2500-6500, 4-spd or 3000 stall converter.
Tests done with 600 CFM carb, RPM intake, headers, crummy heads.
Swapped to 9.5:1 CR, AFR 165 heads, 660 carb.
31-609-5 cam made 480 hp, 421 tq. Specs above. With good roller rockers, motor would make 500/440. Would easily run on pump gas with 0.035" to 0.045" squish.
Old 11-07-2008, 05:31 AM
Here's a smaller grind that would give you a little more midrange and be IMo more fun to drive. Ask Comp for lobes 6258 and 6400 On the intake and exhaust ground on a 110 LSA, you can go with a straight up ICL if you wish or advance/retard it 2 degrees to adjust to your tastes. EDM lifters are required on these profiles, and I HIGHLY recomend it to prevent excessive cam wear.
The specs would be 266/272 adv. 236/238 @.050" .534/.536 lift with 1.6 rockers, and .568/.570 with 1.7 rockers. THIS IS A SOLID CAM WHICH WILL REQUIRE PERIODIC LASH ADJUSTMENTS, if you don't want to work on your car let mw know and I can spec out a hyd. roller or a hyd. flat.
Old 11-07-2008, 05:57 AM
just switching to roller rockers with the same ratio will not gain 20 HP. Not ever. swapping to a full roller setup with the same lift and duration numbers will maybe gain you about 5 hp. They have good purpose, but they are not some sort of magical pixie dust that you sprinkle on your engine to gain 20 hp.
Old 11-07-2008, 06:22 AM
fiscus fiscus is offline
fiscus's barnstar
Wiki editor
Last wiki edit: Calculating tire size
Wiki Edits: 2
I'm pretty sure the '83 mustang has large chamber heads with lower compression ratio (maybe 8.5:1). It would probably be a good idea for you to pick up a set of heads off a 5.0L explorer, they are the gt40p casting and are one of the best flowing production 302 heads. They have the smaller chamber also. You can also use the 87-up mustang and truck e7te heads which are easy as dirt to find, but they will flow the same as your old heads.
If you do go for the gt40p heads you need to be careful which headers you use as some hit the spark plug.
If you're don't want to mess with the heads or compression ratio I would go with the isky 270 mega 318271 (221 degrees @ .050", .496" lift, 108LSA).
It should make some decent power and give you a noticable idle.
Old 11-07-2008, 09:03 AM
I tahnk all of the good advice and will have this winter to make a choice on what to use . This is something I am not in a hurry to do right now . I will be doing the engine swap around March because when the motor and trans is pulled I will have to get everything cleaned up , body work done and the painting done first .
Then I will tear the engine down and rebiuld it . The engine is the easy part for me, it's all the other work that is harder for me to do .
Thanks Again to all !
Jim
Old 11-07-2008, 09:21 AM
when you rebuild it shoot for a 10:1 compression ratio- a larger cam and steep gears is going to need it.
Old 11-07-2008, 01:00 PM
Senior Curmudgeon
Wiki editor
Wiki Edits: 247
Well then, you need to argue with the engineers at Crane. They say they will and that's good enough for me. I value their knowledge and expertise just a wee bit over yours.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Good Hotrod Cam for 302"
What is a good cam For a 390 FE ? 427feracer Engine 2 01-19-2008 02:10 PM
a good street cam 75jeep Engine 5 12-21-2004 06:51 PM
Whats a good cam to match tunnel ram 2506CYL Engine 1 03-04-2004 10:47 AM
How long will the Edelbrock cam lube be good?? Stinky Engine 2 06-15-2003 06:30 PM
In your opinion what is a good starting hotrod? Rubberman2003 Hotrodders' Lounge 18 06-11-2003 07:51 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
