Good Idea '86 2.3L FI Ford Ranger engine for hot rod? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 12:25 PM
I picked up a '86 2.3L FI Ford Ranger engine w/5 speed trans for '29 Ford PU rod I'm building. Pros/Cons? Should I convert to carb?
Old 04-26-2013, 12:52 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
i like carbs but heck, fi is good to go.
Old 04-26-2013, 02:40 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
A friend of mine in Calli has a turbo one in his sand dragster.A ride in that would scare the cr**p out of most people.
Old 04-26-2013, 05:11 PM
LATECH's Avatar
I think its a great Idea. Small in size , lots of stuff available for it.
Carb would be easier. EFI would be a bit more reliable, but not a deal maker/breaker.
Its a ford in a ford. What could be better?
You could turbo it, or pro charger it, or just leave it alone. You can also do a few things to make it appear vintage. Lots of possibilities.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
Valkyrie5.7 (04-26-2013)
Old 04-26-2013, 06:18 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
There's a guy around my neighborhood with a turbo 2.3L Ranger, it's reasonably quick for what it is. The easiest way to go fast would to be to find a wrecked Mustang SVO (good luck) or Merkur Xr4-ti or Thunderbird Turbo Coupe. Those have the best iteration of the turbo 2.3L and will make the best foundation for your build. Swap everything over (engine, trans, harness) and keep the EFI. The 2.3L is a good, tough little motor that will take a considerable amount of abuse.
Old 04-26-2013, 10:32 PM
Wiki Edits: 27
speedway race catalog
The Speedway race catalog has a lot of hop up parts for the 2.3. The 8 spark plugs on the later heads are a pain to change. Some of the 2.3's had a cat comverter in front of the turbo. If you run it hard before the engine has a normal warm up you can cause chunks of the cat to wipe out the turbo. Ford deleted the oil squirter holes in the con rods for a couple years, in cold weather the cylinders didn't get enough lube and scuffed the pistons. The squirter bumps were still on the rods. just the penny pinchers left out the lube holes. If you want to go hog wild you can do some machine work and install a Volvo head, (ford owned Volvo for a while)
2.3l ford ranger, 29 ford, cab conversion
my first idea for a hot rod can it be done by a newb bulldog21 Hotrodding Basics 12 12-23-2008 06:10 PM
MY 1ST HOT ROD ! Is this good????? 71SSGUY Hotrodding Basics 11 08-22-2008 07:52 AM
Looking For Good Hot Rod Movies RIDINGDIRTYNOVA Hotrodders' Lounge 29 03-26-2008 10:03 PM
model a pu street rod buildup using ford ranger frame bjm1956 Introduce Yourself 1 08-12-2004 10:34 PM
ford truck bed trailer for my chevy good idea? IHAVECHEVYPARTS Engine 8 11-14-2002 02:08 AM
