Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Good idea or bad ?
Old 03-14-2011, 08:49 PM
86GMC's Avatar
86GMC 86GMC is offline
auto/truck/equipment tech.
doesnt a drier unload the feed line from the compressor on a truck? if that was the case then you'd have an open line from your tank to atmosphere. if not, or if you can get around it, you'd have to plumb in your governor to work the compressor limit switch, or make the limit switch work the blow off on the drier. the drier cartridge needs to be blown out each cycle for it to work properly, i believe.
