-   -   good info on break in oil (http://www.hotrodders.com/forum/good-info-break-oil-225130.html)
dinger 10-18-2012 09:32 AM
Tech 101: Zinc in oil and its effects on older engines | Hemmings Blog: Classic and collectible cars and parts.
I was reading this today, I wish i had known this 2 years ago when I broke my engine in, I wasted the cam
78novaman 10-21-2012 01:17 PM
Good find Dinger. There is a lot of misinformation out there.
I just broke in my freshly build flat tappet small block chevy using Brad Penn SAE30 break in oil. It was a bit pricey at ~$7/qrt but that is much cheaper than the repair bill on rebuilding a 2nd time!
For the 500mi break in oil I have Meijer brand (yes the department store!) conventional 10w40 which, for now, is SL rated oil. For piece of mind I replaced a qrt with Risline ZDDP oil additive.
AMSOIL makes a synthetic oil with the required zddp levels called Z-ROD that I may use after the 500mi break in. It's $10+qrt though. Comes in 10w30 & 20w50 varieties.
1971BB427 10-21-2012 05:35 PM
I buy Brad Penn locally for $70 a case. I used their 30wt. to break my cam in, along with a bottle of Comp cam breakin lube. Can't be too careful with a cam breakin for me.
hp246 10-21-2012 07:58 PM
Nice reminder Dinger.
