good info on break in oil
Tech 101: Zinc in oil and its effects on older engines | Hemmings Blog: Classic and collectible cars and parts.
I was reading this today, I wish i had known this 2 years ago when I broke my engine in, I wasted the cam
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
| The Following User Says Thank You to dinger For This Useful Post: | ||
Jim Rockford (10-20-2012) | ||
Good find Dinger. There is a lot of misinformation out there.
I just broke in my freshly build flat tappet small block chevy using Brad Penn SAE30 break in oil. It was a bit pricey at ~$7/qrt but that is much cheaper than the repair bill on rebuilding a 2nd time! For the 500mi break in oil I have Meijer brand (yes the department store!) conventional 10w40 which, for now, is SL rated oil. For piece of mind I replaced a qrt with Risline ZDDP oil additive. AMSOIL makes a synthetic oil with the required zddp levels called Z-ROD that I may use after the 500mi break in. It's $10+qrt though. Comes in 10w30 & 20w50 varieties. |
I buy Brad Penn locally for $70 a case. I used their 30wt. to break my cam in, along with a bottle of Comp cam breakin lube. Can't be too careful with a cam breakin for me.
| Break-in oil | goldenbullet44 | Engine | 6 | 08-28-2010 07:39 AM |
| Custom intake tube info (Cavalier, but good info for all) | TheVis | Engine | 11 | 02-09-2007 04:44 AM |
| New cam break in info | 327NUT | Engine | 18 | 12-16-2006 11:12 PM |
| bad or good: engine break-in | darom | Engine | 4 | 02-01-2005 10:35 AM |
| good break-in procedure?? | BanditT/A | Engine | 4 | 03-25-2004 05:56 AM |
