Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Good intake?
Thread: Good intake?
Old 04-17-2013, 10:13 PM
KyleG KyleG is offline
Good intake?
What would be a good intake to pick up some low end torque? Right now, the motor has a Torkii 2, edelbrock. Holley 750vs. 350, .030 over, flat tops, sadly do not no correct cr but probably 9:5 to 10:1, but could be higher.. Cam is a hydraulic flat tappet, 508 lift and 313 duration( lots of my low end power issue, i know.), not sure specs on the headers they are long tube, 2200 stall turbo 400, 4.11. Heads are 461 double hump heads, Sure the springs are not stock but do not know what they are, no porting or polishing. 1.5 arp rockers. Gm hei.
Right now, the rear tires will hardly spin without a little brake.. Does have good new tires though, 275-60-15 bfg radial ta.
Anyone know an AFFORDABLE intake i could swap to, that'd help a little.? Or other ideas to pick up some low end.. Already considering another cam.. Sounds good, but does not really come in till a little after 3000. After that it is a rocket ship. But till then. not much going on.
It is in a 70 c10.
