Good intake for a 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2006, 07:43 PM
Ozz1967's Avatar
Air Force Guy
Hey guys,
The stock intake manifold on my 305 powered 84 Trans Am is pitted out really bad at one of the corners where it bolts down and I have to replace it because I can't get a proper seal anymore. Would it benefit me better to get an aftermarket intake manifold or should I go with a stock replacement from GM? If I go aftermarket, which would help me the most? Keep in mind I have the stock heads and stock exhaust manifold on the car. I do plan on replacing the motor early next year with a 383 for which I already have the block and a set of vortec heads...can I buy a vortec intake and use the Vortec heads (Originally off a 350) on this 305? Thanks!
Old 05-31-2006, 11:04 PM
I don't know if the intake valve on the Vortec head will clear the 305's bore.
If I were you, I'd find a good stock intake and use it. You could possibly use a Performer, but on a stock 305 I think you'd soften your throttle response, and only gain power in the very high rpm range (if at all), while losing some in the low- to mid-range. Save your money for the 383.
Old 05-31-2006, 11:41 PM
User
I wouldn't buy a new manifold or anything if your going to build a whole new motor later.
Maybe check the Junkyard or ebay or something, either for a stock intake or a used performed (Ebay...) since I have seen performers go cheap, but I'd say a stock intake would go cheaper...but not N.O.S....just used. I wouldn't want to go through the trouble of putting new heads on the engine, then buying a new intake, putting it all together, etc.
-GF
Old 06-01-2006, 12:34 AM
Ozz1967's Avatar
Air Force Guy
Check Ebay...That sounds like the smarter thing to do. Can't believe I didn't think of that myself. Thanks guys. I'll see what I can find.
Edelbrock Torker Intake - What's it good for? SAATR Engine 6 09-16-2005 01:23 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 01:56 PM
Chevy 305 Intake help! JohnyR17 Engine 2 12-25-2003 09:34 PM
port matching the intake. Jmark Engine 9 12-08-2003 11:13 AM
305 heads on a 327 good or not engine-rookie Engine 1 05-03-2003 04:00 PM
