A good intake for this setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2010, 05:42 AM
I want a good intake to match this setup what you do guys recommend..Here's what i got:
400 sbc virgin block(stock internals)
462 heads ported n polished
501/501 comp cam 292 grind
1.5 roller rockers
edelbrock 800 cfm carb
th350
3.73. gears
Hooker super comp headers.
Any thoughts would be great..
Thanks
Old 05-23-2010, 06:31 AM
I would use the edelbrock RPM intake. not the air gap, just the regular RPM.
I don't like RPM air gaps because of bad cold weather manors (slow warm ups) and crap falls under the intake. Not worth the 2 extra hp.
don't like edelbrock carbs, especially with big cams. I would use a holley 3310 with a 4.5 power valve.
That 292H a good cam, but I hope you are running a 2800 to 3200 rpm stall and are using the correct valve springs.
what is the compression ratio?
furthermore, use an oil additive at break in and at each oil change. www.zddplus.com. todays low emissions oils are not good for big flat tappet cams.
finally, that cam will require lots of ignition timing at idle. around 20 to 25 at idle and 38 to 40 total.
Old 05-23-2010, 07:50 AM
302 Z28's Avatar
I think it is Holley that makes a 67-69 Z/28 clone intake. I love the older Z/28 intakes for street use. Also go with the Holley carb as indicated.
Vince
Old 05-23-2010, 02:31 PM
techinspector1's Avatar
Wiki Edits: 326
Vince
Have read a couple of places that the Edelbrock RPM and the Weiand Stealth are both Z-28 knock-offs. Don't know about Holley. I do know that the RPM and/or the Stealth make more power from idle to 6000 on the DynoSim than any other manifold I have tried.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Oil consumption due to possible sucking oil from intake valley..signs ? y2k600f4 Engine 10 07-31-2010 04:40 AM
Good ventilation setup Toyman Garage - Tools 0 07-05-2005 06:42 AM
351C intake manifold question....??? Steve-0321 Engine 3 04-25-2005 07:44 PM
Dart intake? Brodix or Dart Heads? Slowass72 Engine 3 01-20-2004 04:52 PM
