Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - good news___bad news ( flexplate & quadrajet )
Old 09-10-2012, 07:27 PM
LEROYDOZOIS LEROYDOZOIS is offline
Originally Posted by oldbogie View Post
Old Q-Jets often wear out the throttle shaft bore in the housing and pull enough air to idle on right around the shaft(s). The solution is to put brass bushings in there to restore the proper shaft to bearing surface clearance.
Bogie
i just installed bushings on both right/left side of the truck, i thought the whole problem with the carb was that, and i was dead wrong
