Good Paint & Clear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2011, 05:43 AM
GMCTRUCKS's Avatar
Good Paint & Clear?
Hey members im planning on getting my hood and roof painted now the rest of the truck looks good still and my truck is a 93 model now it was painted when it was new by some customized company called Trailmaster and the fade paint job has held up real good except for the hood and roof since it wasn't painted by them.
My question is why has it lasted so long and looks so good did they use more clear when they painted it when it was brand new or painted and what brand of paint & clear should I buy and what was the trick they used for it to have lasted this long compare to the paint that GM used on hood and roof?
I have seen some shows on TV to where they apply six coats of clear because when it's wet sanded two or three coats come off. Please excuse me for being so dumb on this matter I know nothing about this stuff and I hope you guys understand what I mean if not im sorry.
Thanks! Roland
Old 09-13-2011, 08:24 AM
skip99's Avatar
factory paint is pretty thin, aftermarket base clear would hold up better as you can see. ppg dbc will e a very close match on color, and use their omni or better clear,,2042? you might even consider, painting the hood and roof, and just scuffing the rest and put one coat of the same clear on it all to match...
6 coats of clear is not necessary, if it was preped right... unless its a show car. then they usually spray a couple coats, block it and spray clear again then cut and buff..
Old 09-14-2011, 03:06 AM
GMCTRUCKS's Avatar
Thanks!
Clear coat on old paint Baggers Body - Exterior 10 06-18-2010 05:38 AM
base/clear paint for underside of vehicle or other paint? hrc200x Body - Exterior 5 06-27-2007 09:55 AM
sanded through clear to paint..how to fix? makaveli200369 Body - Exterior 9 07-24-2006 05:15 PM
what color pearl in clear looks good on a red 66 mustang joeguz Body - Exterior 1 04-19-2006 08:26 PM
good engine clear Scuzzy Engine 3 08-09-2003 12:11 PM
