Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A GOOD Portable tool kit???
  #20 (permalink)
Old 11-11-2007, 06:17 AM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
1st Report:
So far so good
on the + side
~ It has just about what you need to not have to walk back & forth Even E torx & T torx up to T 70
~ All the tools have a good feel to them the rachets are fine toothed & not sloppy the sockets have a good "ting" to them when tapped together ,
~I used a couple on my Snap~On Air ratchet & it did not break of blow the chrome off
~ On the - side the box is a bit of a PITA to open & close it has foam inserts between the segments that either have a static charge or go flying away into the breeze.
~I will have to do something Innovative with this,
~The little sockets & think I will cut the back of the plastic out & put some kind of magnet to hold them in there I have not done it yet but the potential for it to become a big mess fast is very real.
~I am not too crazy about the latches they will wear out relatively Quick I am sure
~ Its Heavy
So far so good a Very good organized bone yard set.
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
