Good quality clear for a resonable price? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-12-2013, 11:23 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I use to use the SPI Universal and loved it but it got to expensive for me.
I switched to SPI "EURO" clear, around $100 a gallon w/ activator (delivered)
and I like it just as well, maybe better because it seems to be a harder
clear which is nice for dark colors, makes it easier to remove the swirls.
  #17 (permalink)
Old 02-12-2013, 09:53 PM
mitmaks's Avatar
Last journal entry: Grille
I used DC5020 clear on my projects (see my other threads) and they turn out great. For the price you just can't beat it.
http://www.sherwin-automotive.com/me...ish/DM2007.pdf
  #18 (permalink)
Old 02-12-2013, 10:01 PM
Just out of curiosity how does this clear compare to the finish 1 fc720??
  #19 (permalink)
Old 02-12-2013, 10:08 PM
mitmaks's Avatar
I haven't used Finish 1 but Finish 1 is supposed to be lower quality according to this chart
http://www.sherwin-automotive.com/~/...oatMatrix.ashx
  #20 (permalink)
Old 02-13-2013, 04:00 AM
What you say seems to make sense because universal is apparently soft enough to buff at any time, but have you done any tests? I have seen this stated by some others also, but then Barry says that all his clears are similar as far as hardness.
I haven't tried either clear yet, but would like to use one that would not be so likely to get fine scratches from normal use of the car. It just makes sense that if it buffs so easy, then it would also get marked or scratched easy.
  #21 (permalink)
Old 02-13-2013, 04:55 AM
jcclark's Avatar
The Penny Pincher
I haven't done any tests,
The Universal just seems softer to me than any clear
I have ever used. The Euro seemed harder.
Either way, I like them both, it's the price that made me try the Euro.
The price is actually closer than it looks when you consider
the Universal with activator makes 2 gallons of clear,
where as the Euro makes 1.25 gallons.
But the Euro is definitely thicker, I reduce it 20%.
(So I guess it actually makes a little more)
The Universal flows better, I'll pick it when I don't want to buff
afterwards. It's great for bumpers.
I still think the Euro is better for dark colors that are going to be buffed.
  #22 (permalink)
Old 02-13-2013, 06:17 AM
deadbodyman's Avatar
Wiki Edits: 11
Its only SPI for me ,great products at a reasonable price with the best tech support you'll ever see...
I've tried everything else in search of the the best at the most reasonable price and if you spend less than what you can get SPI for your not getting a high quality product...This is high end stuff to be compared with the the top brands...My hunt is over...yours will be too if you were to try it....
  #23 (permalink)
Old 02-13-2013, 07:18 AM
jcclark's Avatar
The Penny Pincher
Another thing I would like to add.
I still recommend the Universal Clear to anyone that's not an
experienced painter. It's the easiest clear to get good results
with because it flows so well and is so easy to work with.
It's the most "user friendly"
  #24 (permalink)
Old 02-13-2013, 10:42 AM
327amc's Avatar
Owner of a broken cart
Best clear ive ever used is Motostorms Glamour Clear. (motostorm.com)
SPI used to be my favorite clear, but one day I ran out in the middle of a job, and had to use the Moto I had just got in. Not only did it have quicker build, but it went farther. I was able to mix up the same, or less, and achieve more coverage.
The gloss is the best ive ever seen straight outta the can. And buffs like a dream anytime, being a poly.
  #25 (permalink)
Old 02-13-2013, 11:15 AM
FRANKBULLITT's Avatar
Used sherwin williams on lotus
here it is with clear coat 2 coats 600 2 coats done no wheeling nutn just like oem
Name:	lotus clear coat.jpg
  #26 (permalink)
Old 02-13-2013, 12:03 PM
put up or shut up
PPG gets my vote. Sands well and won't die back on you. When you shoot bad clear they seem to sand like rocks and you're always buffing them again, at a later point, and/or it will die back on you. What's the point of taking more material off if that's your last line of defense from the elements? Want that deep gloss that stays for years get PPG. Just my opinion.
  #27 (permalink)
Old 02-13-2013, 12:11 PM
Acme
Been shootin' some bike stuff with Acme Finish One. Have had pretty good luck with it. I use 710 spot, but 720 is the overall stuff.
  #28 (permalink)
Old 02-13-2013, 12:37 PM
Last journal entry: 1965 sunbeam Tiger
inexpensive clear coats
im an older painter and have used most all of it...it was mentioned about " wanda " I agree that it is an affordable product with the "AXZO NOBEL' symbol behind them...a newly acquired line with a little Sikkens engineering behind it..I cant comment on the durability nor the longevity of U.V. protection...but it does give you nice results with ease of color sanding and polishing...each of us have our favorites but sometimes its ok to go outside our comfort zone to spray something less expensive...I think its worth a try
  #29 (permalink)
Old 02-13-2013, 11:48 PM
327amc's Avatar
I did this demo long ago. I think the parts were 7days cured, in the picture.
  #30 (permalink)
Old 02-14-2013, 04:56 AM
jcclark's Avatar
The Penny Pincher
I've used a lot of different clears over the past 30 yrs,
a lot of the cheapest ones out there and a few of the best.
Everyone held up just fine.
The differences came more from the prep and application than the brand.
some sprayed easier, some harder, softer, but the end product
looked just as good if buffed properly and lasted just as well.
The Following User Says Thank You to jcclark For This Useful Post:
Trucknut (02-19-2013)
Quality vs. Price MattsonsCustomRad Hotrodders' Lounge 28 06-04-2011 02:08 PM
whats a good price for good th-350 and 400 cores? jeffvega Transmission - Rearend 7 03-08-2009 04:15 PM
Good quality Wire T-bucket23 Electrical 6 04-04-2007 11:28 AM
Soldering station - good quality/price compromise? kick_the_reverb Electrical 9 12-03-2006 05:08 PM
Good quality..... BstMech Hotrodders' Lounge 9 08-23-2003 02:07 AM
