Hotrodders Bulletin Board
#1
A good rust inhibiting paint easy to source locally?
Sup' guys
Can anyone a recommend a durable rust inhibiting paint that's easily found in a local auto parts store, Hester Zipper, Wal-Mart, etc... I'm going to strip my undercarriage while swapping in a new driveshaft, and want to remove all rust, inhibit it and then coat it with Herculiner. I would order Rust Bullet but I'm pressed for time. |
#6
re: A good rust inhibiting paint easy to source locally?
have you taken a look here? chassis saver
Just look for a local distributor on the links on the left Brian kc0kfg |
#7
Awesome. Zero Rust seems to be the most commonly available on the retail level.
Zero Rust wasn't on my radar but after some googleling, I'll see if our oReilly's has some. |
#8
check they http://www.kbs-coatings.com/ they have a retail locator. I found it at a local parts store. I am really impressed with the product.
#9
The only truely "rust inhibiting paint" is used by preparing the surface and applying epoxy primer. Anything else will be a temporary cover up that will rust again later.
There are a bazillion threads on here concerning rust inhibitors. Reading of what has already been posted on the subject will give you quite an education on the matter. Aaron |
Back to top |
Similar Threads for: "A good rust inhibiting paint easy to source locally?"
| Rust, metal work, sanding, Paint!! | 1970Chevy | Body - Exterior | 9 | 06-28-2007 06:00 AM |
| rust under paint | charliec | Body - Exterior | 5 | 10-19-2005 09:55 AM |
| easy paint job info needed | pjd | Body - Exterior | 1 | 08-09-2005 09:30 AM |
| Looking for a good Paint and Body Shop in the OC Southern Cal Area | Mitch | Body - Exterior | 4 | 11-03-2002 05:26 PM |
| where can i get a good paint | integra_2222 | Body - Exterior | 3 | 07-29-2002 05:21 AM |
