Good sbc350 buy? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2011, 07:25 PM
Last journal entry: brakes
Good sbc350 buy?
Been awhile that I've posted but the truck has been coming along as budget allows. I wanted to get your guys take on this potential buy, looks like a good deal but need some additional opinions. Some things to keep in mind, guy has no way of showing me it runs as it's in storage. I'm not sure if the heads are "unleaded ready".
Thanks for the help!
http://baltimore.craigslist.org/pts/2529322128.html
Old 08-17-2011, 07:38 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
In at nutshell, no, it is not a good buy. 1973 engines were extremely low on compression, tons of emissions crap to wade thru, etc. The famed LT-1 350 was rated at 250 HP in 1973. You can buy a 96 or later Vortec 5.7 that will have the desirable Vortec heads, one piece rear seal, and a roller cam block for the same money if not less. Much better engine to be working with.
Old 08-17-2011, 09:34 PM
bigdog7373's Avatar
Of course it's fast
Wayyyy expensive if you ask me. Heads probably dont have hardened seats. Compression is usually low, like crd said. If you can get it for around $300 without the tranny, then it would be a better deal.
Old 08-17-2011, 10:24 PM
Wiki Edits: 31
'73 would have hardened seats, which wouldn't be an issue.. not a bad deal if you could hear it fire, or bump it over by hand to check compression.. Add up the parts cost. Probably good for 260hp, compression around 8.5:1 most likely which is reasonable.. It's worth $1k with the trans and other parts it comes with. that's relativly cheap if you add everything up... Even if a '73 350 is not the best 350, it's a decent deal
Old 08-18-2011, 06:49 AM
DoubleVision's Avatar
It appears to be a smog 350 to me. One in which the owner has thrown some stuff on it to dazzle the eye as many are pulled in by chrome dazzle into thinking it looks that good it`s gotta be fast too. If only that were true.
I`m with Cool Rockin` on this, I`d get a Vortec 350 which comes with what you need to build a butt kicker.
Building a mpg sbc350 bigals77 Engine 8 05-01-2011 01:00 PM
Sbc350 SBC355 Engine 5 04-01-2008 01:22 PM
s10 transmission/sbc350 53belair Transmission - Rearend 1 01-22-2007 01:00 AM
good cam for a daily driven sbc350 66truck4spd Engine 2 11-22-2003 04:03 AM
sbc350 that eats cam lobes eblyon Engine 20 06-15-2002 10:49 AM
