A Good set of HYD Roller Lifters that can rev to 7000rpm
I looking for a Great set of Retrofit HYD Roller Lifters that can rev close to or to 7000rpm.
I'm using the AFR1103 heads 210cc competition heads I swapped the 710 solid roller springs for the AFR#8019 hyd roller 650 lift springs. I really appreciate the advice if u guys have any suggestion on what Retrofit HYD Roller Lifters I should go with thanks. Des |
The reason i didn't really go with solid roller, I just didnt want to go thur the trouble of trying to adjust the valves and the headache especially for my first engine build so my engine builder told me to stay with HYD roller. Maybe on my next engine build I probably might go soild roller....
Some good Info/Ideas here, may help you.
Solid Roller Power From Hydraulic Lifters: Roller Lifter Install - Solid Roller Power From Hydraulic Lifters - Car Craft Magazine Three-Way Cam Lobe Shootout: http://www.carcraft.com/techarticles...e/viewall.html |
Good luck. |
Yeah I have a comp rev kit just was looking for some good lifters that will at least get me to 6800 if not 7000rpm, any suggestions?????
But when I was researching this same thing a year ago, I had taken a hard look at the Lunati retro hydraulic roller lifters. They're designed to be compatible w/higher than normal spring pressure that's usually needed for elevated rpm use, so you might want to start there. Using the lightest possible valve train components will also help in general. Good luck. |
bougt, also ill have to take the afr 210cc heads back to summitracing, I got them custom order for 650 hyd roller on the 210 heads instead of the 710 solid springs that cam with them... idk knowing me ill just keep hyd roller and just call it day |
The springs that are used for a STREET mechanical rolller are not the same as whats used on a race roller.
Your street rolller will not have .710" lift. It will be .630" or less. (1.5 rocker) Keep the heads and get and add the right springs to suite the roller cam. Get a complete street roller cam and kit and install it. EG: Comp #K12-771-8 Mechanical street rollers use more spring pressure than a hyd roller but a bit less pressure than typical competition race roller cam. Typically 160 to 250 seat 400 to 550 open on street rollers. Follow the cam makers recomendation for that specific cam. The street roller cams made on the cast cam core tend to go easier on the spring pressure. (low cost) The street roller cams made on the billet steel cam core can use more pressure. (higher cost stronger core) Why pay someone to screw it up when you can do it yourself, correctly in a short time. It is not hard and needs to be done correctly. Most, even so called pro mechanics don't do it right. But you can. Note* Doing the job correctly does not equal Hard to do. Last edited by F-BIRD'88; 10-07-2012 at 11:13 AM. |
yeah true , maybe ill just put a 50 to a 100 shot of NOs on it...hahaha lol then ill be close with the hyd roller cam
| Hyd. Roller lifters on Solid roller cam | danrace1 | Engine | 6 | 01-28-2010 05:21 PM |
| Hyd Roller Cam W/Solid Roller Lifters? | RoyLeoGracie | Engine | 12 | 02-03-2009 10:15 AM |
| noisy hyd roller lifters | 65Guera | Engine | 22 | 05-13-2008 03:17 PM |
| Hyd. Roller lifters problems | hotrodf1 | Engine | 121 | 10-25-2007 01:31 PM |
| Hyd Roller lifters | underdog305 | Engine | 7 | 10-13-2006 08:42 PM |
